Author Topic: TV Repair  (Read 2759 times)
Offline ZaXaZTopic starter
TV Repair
« on: October 17, 2018, 03:45:01 pm »
Hello
So my tv has started doing the famous blinking with the standby led. (i did not know they had a blink code witch I did not note it down)
I hoped it would just be a simple case of a capacitor that went BOOM! but none of them have blown the top so now I have no clue what to do.
The TV is a Philips 47pfl6877T/12 I live in Denmark but for some reason, 90% of all I find on google with this tv model is in polish/Russian witch won't help much.
I did manage to find a service manual, but I can't find the places on the physical print to measure on.
I have taken it out to do a closer visual inspection and can't find any damaged parts on the PCB. all I got to work with is a somewhat cheap multimeter and a soldering iron
Is there anyone who would be so kind as to assist me in trying to fix this tv?
I know it will take some time, and is far from a 5 min thing but I'm willing to put in the time if it means there is a chance I can repair it compared to buy a new tv
my current knowledge of this is very basic
Files:
philips_chassis_qfu2.1e_la.pdf Is the repair manual
Pictures
https://drive.google.com/drive/folders/1VmpakqvjnreEHhgTroc2fJBEnO4JIu1-?usp=sharing
Offline PKTKS
  • Country: br
Re: TV Repair
« Reply #1 on: October 17, 2018, 04:18:24 pm »
Unlikely to be just a cap.
This CHASSI  uses a proper troubleshooting procedure
The manual is very handy - and as you already found it you should
follow the "SETUP" in Diagnostic (Service) mode primary mode
Once you start the manual will guide you in converting the error codes
to figure out what it is wrong or at least some clue to start
A considerable practice is needed to open and deal with such CHASSIs
the proper service mode page is shot here as attach...
find that page to start the "SERVICE MODE"...
Paul
Re: TV Repair
« Reply #2 on: October 17, 2018, 04:33:29 pm »
it won't turn on at all, and I cant get it to flash again so that makes if very hard to get to use this "SERVICE MODE"
also i fail to find nay translating of blinks in the manual?
Offline PKTKS
  • Country: br
Re: TV Repair
« Reply #3 on: October 17, 2018, 04:42:34 pm »
Yes don't expect that it will magically 'turn on'
The Service Modes each has it's own reason to troubleshoot
some particular section
The ERROR CODE table is in the next page... of my shot
To enter all the modes they also suggest their tool (should be
some sort of firmware probe)...
I doubt anyone outside the authorized should have this..
so we need to carve the tips on the manual
It looks that your version of the manual may be missing
or be just a summary ...
Two more shots to see the propr pages
Online SiliconWizard
Re: TV Repair
« Reply #4 on: October 17, 2018, 04:45:48 pm »
It may still be a defective capacitor. They don't always go as far as have their vent blown up. They may just inflate a bit (bulging vents) and that'd be barely visible. They may even dry up without any significant external sign.
As a first step, I would still unsolder all the electrolytic caps (there are not that many), control them and change them anyway.
Also look for dry solder joints. From the pictures it's hard to see well.
Offline PKTKS
  • Country: br
Re: TV Repair
« Reply #5 on: October 17, 2018, 04:54:08 pm »
May be.. but the chassi is BIG.. and all digital
That means a lot of guessing
A clue were to start will help
Re: TV Repair
« Reply #6 on: October 17, 2018, 05:15:57 pm »
I have no clue how to read that "diagram" layer one has a lot of numbers in common and it seems unlikely that it would blink over 30 times with some of the numbers in layer 2 is.
I can't remember how many times it did blink but it was 3-5 ish +/- 1 or 2
But there is under 10 caps I could remove them and test them, tho I'm not sure how to do that with only a multimeter most of the videos that say "test caps with just a multimeter" then use another tool  |O
This is my MM i wish i had a better one just ain't got the cash for it atm and all i normally use it for is to test is there is a connection and/or somewhat close to 12 volt  (working on cars)
Offline Cherenkov11
  • Country: mx
Re: TV Repair
« Reply #7 on: October 17, 2018, 05:39:51 pm »
First of all, I have a little experience fixing tv's, but when we face a problematic TV our first thought is always the PSU because is the mos likely to fail, but not always, with new TV's, especially smart ones, the main board may be the real problem.
Recently I fixed a LG smart TV, no image, no backlight, no audio, no nothing, only the standby LED. I though that the PSU was the faulty one, but not, I checked all the volatges and all were correct, the real problem was on the main board, I had to reflow the main chip, heating it and the TV turn on again.
I'm not saying that you have the same issue as mine, I'm just saying that the PSU it is not always the problem, if you have image but not backligh, must likely the caps on the inverter are faulty. But if you have similar symptoms as the TV I mentioned, the main board could be the real problem.
Note: I don't recommend you test the capacitors, just replace them, if the tv has a couple of years working it is pretty normal that caps fails, even if they look good physically.
Re: TV Repair
« Reply #8 on: October 17, 2018, 05:55:48 pm »
Tv is 4-6 eyars old i would bet.
most reviews of this tv is from 2012 so around there.
the im not sure if its hard to see if there is an image but no backlight i have never see that. but i thing i got NO: image no light and a standby led that blinks a hand full of times and pause for a while and keeps blinking i just assumed the pause was a recharge time
Offline Cherenkov11
  • Country: mx
Re: TV Repair
« Reply #9 on: October 17, 2018, 06:05:46 pm »
I thinks, firstly you need to check if the power supply is working correctly, in some service manual there is a complete procedure on how to check all the voltages, so you need to do this first, and when you are 100% that the PSU is working correctly it is time to check the main board, that to me, it most likely the cause of the problem
Re: TV Repair
« Reply #10 on: October 17, 2018, 06:17:31 pm »
That was mostly my plan also.
i am how ever not sure where to  check all the voltages at. the first one it wask for is C306 and i cant find that sucker any where. i can find C300-C303
I marked them with color to the point i assuem they corolate with. but i cant find any more than that?
Offline Cherenkov11
  • Country: mx
Re: TV Repair
« Reply #11 on: October 18, 2018, 02:35:32 pm »
Well, sorry for taking a long time to answer, I go to the college and don't have a lot of spare time. But, what I got is that I found the schematic of the PSU, I'm gonna attach it, there it is the voltages of the power supply. But, for my expierece if all the connectors are detached you only have to get the standby voltage ~3.3V, PIN 1 CN4, so, to turn on the power supply you may jump the STANDBY PIN 2 to ground (PIN 3, 4, 9, 10)and now you are going to get the 12V on all the pins marked with 12V3.
Check that out and confirm the voltages. The other part of the power supply is for the backlight driver, but to turn this on the lights must be connected to the board, the BL_ON pin 11, may turn the backligh ON, but for the diagram I think it must put it up, but I don't know with what voltage, maybe 12V.
Re: TV Repair
« Reply #12 on: October 19, 2018, 05:10:00 pm »
i got it blinkin again.
it keeps repeating 2 blinks rather close togeather then a 3-5 sec pause then repeat.
Re: TV Repair
« Reply #13 on: October 19, 2018, 05:34:40 pm »
mesuring on CN4
(no short from ground to pin 2 or anything but power connected to powersupply)
pin 1 to ground = 00.0mV
(short from ground to pin 2 or anything but power connected to powersupply)
pin 1 to ground = 00.0mV i did do a quick small jump witch i did not get to note.
with no power i tested for ground spots on the CN4 and i dont have ground on pin 14 but 1 do get ground on 11 and 12 is that the way it should be?
when i plug in power GT 1 and 2 make a spark is that normal?
« Last Edit: October 19, 2018, 06:08:05 pm by ZaXaZ »
Re: TV Repair
« Reply #14 on: October 19, 2018, 06:34:29 pm »
I know i should have real tester for a cap, but i don't have one so i just tried to see how many V they individual had when the tv was in standby witch si way less than the number on the side
C907 is having 12,3V on standby and 17,71-17,78V when the tv is dopoing the blink code thing. it's marked on the side to 50V is that a valid way to test is ifs dead?
Offline m3vuv
Re: TV Repair
« Reply #15 on: October 20, 2018, 11:10:43 pm »
this screams high esr to me!!,if you dont have an esr meter buy or make one,its always my first port of call with switch mode power supplys,im suprised no one mentioned it!!
Re: TV Repair
« Reply #16 on: October 20, 2018, 11:14:59 pm »
what do u mean with this high esr?
Re: TV Repair
« Reply #17 on: October 20, 2018, 11:41:48 pm »
I'm afraid not.
But as I suggested, you'll lose a lot less time replacing all electrolytic caps, won't be very expensive. And if the problem lies elsewhere, well you have them changed preventively.
Offline nano111
  • Country: hr
Re: TV Repair
« Reply #18 on: October 29, 2018, 06:42:23 pm »
hi,
I do not know if you have same psu board but look this in attach.It helped me .
Re: TV Repair
« Reply #19 on: October 29, 2018, 07:28:43 pm »
hi,
i will have a look at it thx!
