Author Topic: SMD Component Identification Help  (Read 546 times)
Offline TesttechTopic starter
« on: December 21, 2024, 10:19:19 pm »
Greetings,
I am working on an RF circuit and have encountered SMD components that I do not recognize. Please see the picture. I have outlined the four parts in question.
They have white translucent bodies, no marking other than the partial black band.
Resistance measured across these varies, and I suspect that the reading are from other circuit DC paths. I suspect capacitors.
Does anyone know for certain?
Thank you!
Online fzabkar
Re: SMD Component Identification Help
« Reply #1 on: December 21, 2024, 10:44:26 pm »
The unmarked ones look like chip inductors. If so, then they should measure close to zero ohms.
« Reply #2 on: December 21, 2024, 10:48:52 pm »
I don't think they are inductors, as some measure in the 1000's of ohms, and other do not.
Online fzabkar
« Reply #3 on: December 21, 2024, 11:56:56 pm »
Precision resistors?
« Reply #4 on: December 23, 2024, 12:17:10 am »
fzabkar,
You are correct, these are inductors!
 I am in the process of working out exactly what is going on. Some of these components have clearly failed open circuit. Unfortunately, there are no value markings, so I am not sure how to estimate the correct values.
Some are in the signal path, (3-4 GHz), others seem to be bias filters for the transistor gain stages.
Offline eb4fbz
« Reply #5 on: December 24, 2024, 11:40:57 am »
Multilayer inductors
Offline u666sa
  • Country: ru
« Reply #6 on: December 24, 2024, 12:14:30 pm »
Which one is open circuit?
« Reply #7 on: December 24, 2024, 07:41:36 pm »
More progress with the component identification.
The components in question are both inductors and microwave capacitors. Unfortunately they appear almost identical, and have no value marking.
The inductors have a black square located at one end, while the capacitors have a black square in the middle of the white body.
I drew the schematic and it became clear that the capacitors are connected from a DC point to ground, or in a series signal path, (3.5 GHz), while the inductors are essentially bias chokes.
It looks like the RF transistor is dead, replacement on order.
Thanks to all who have responded.
