Electronics => Repair => Topic started by: ElectricGuy on February 02, 2016, 03:12:29 pm
Hi;
Can somebody help me confirm that the component on the red circle of the image is a SN74LVC1G3157.
The component is marked 3157 and is placed in a TFT display board.
IT gets really hot, over 160º measured with a "special edition" Flir E4, and if i freeze it with freeze spray the display board works.
Also, is the package SC-70?
Thank you.
The part might be SGM3157 (datasheet shows 3157 as the marking instead of C5 on the other P/N), but comparing the two datasheets they look similar enough to probably be interchangeable.
http://en.sg-micro.com/index.php?m=default.products_show&id=188 (http://en.sg-micro.com/index.php?m=default.products_show&id=188)
That would also match the SC-70 package too.
So probably the part is not broken but heavily overloaded?
Just an uptdate.!
Changed the part and it works great now!
