Dear Joseph: I see you are in Belgium, I have good friends in Louvain and Tienen.
1. A5: Tant Cap polarity in photo: - towards corner of board, + towards center of board
2. Why choose...
The TEK designers in late 1980s used mostly TH and A5 SMD was just beginning to go to production. In fact earlier A5 boards were thru hole, so this was one of the FIRST TEK SMD boards!
The components were still in new development especially ELKO SMD and tants. The cap mfg did not qualify all the materials for use with certain SMD board assembly, solder profle and flux as these were still evolving. The seals at the case><lead was susceptible.
Finally neither the capacitor mfg nor TEK could envisage these scopes would still be working 30-40 years later! Normally consumer gear life is 5-10 yrs max, instruments 20 yes and industrial contreol, telecom, etc 40 yrs (Central Office)
The temperature cycling and improper SMD solder/cleaning practice probably caused the seals to break and start to corrode.
I must says that this is only one of a few issues on the Methuselahs!
The other is the TH aluminum EKLO caps on A2, A3 power supply boards: Many go bad over time, and have low C or high ESR. In addition the RIFA X and Y line filter caps crack and burn especially on 240 V use.
For long life and reliable service, a rework suggestion:
a. "recap" PSU A3, A2
b. Replace Dallas NVRAM with new socketed or the DIY magnetic FRAM
c. As you see replace all SMD lytics on A5
Afterwards a full CAL is recommended.
Notice that replacement of NVRAM Dallas DS1227 will mean to read data on existing version and these 28 pin TH are especially hard to unsolder without damages.
GOOD LUCK
Jon in Paris
PS:
https://groups.io/g/TekScopes dedicated to TEK, moderated with some ex TEK EE and techs
Just the ramblings of an old retired EE
