Thanks!! I saw on YouTube, that small components like SMD Resistors & Capacitors, came of easily with just flooding the area with flux, and then bring it up to a resnable heat, and it came of very easily.
3 questions though;
* 1:Is a Hair Dryer, good enough to obtain the flux heat?
* 2 Does SMD ADHESIVE, cause a problem when removing these components?
* 3: Is there a difference between 'Bakers Flux' and normal SMD Flux, and can either be used in this case?
Thanks Simon.
