Author Topic: SMD Diode code 75  (Read 2957 times)
Offline sub2001zeroTopic starter
SMD Diode code 75
« on: January 27, 2018, 04:09:38 am »
Hi need some help finding are replacement. The smd has code of 75 with dot above the 75, has a gray strip  on the left with two legs.
Offline DTJ
Re: SMD Diode code 75
« Reply #1 on: January 27, 2018, 04:26:59 am »
Cut and paste from a case code list I have:
75    015AZ7.5   Toshiba
75    BAS70-05   Siemens   SOT23   Dual BAS70
75    BFQ75   Siemens   CerecX
75    BFQ75   Siemens/Infineon   SOT173   pnp fT 5GHz 12V 50mA
75    R2DZ7.5   Toshiba
75-    BAS70-05W   Philips   SOT323   dual cc BAS70
You say 2 legs - do you mean 2 contacts in total or a package that has 2 legs + a tab?
« Reply #2 on: January 27, 2018, 04:30:05 am »
thank you very much!
« Reply #3 on: January 27, 2018, 04:35:25 am »
it has 2 tabs on it end with the number 75 in the center, The ones you list has 3 tabs
Offline DTJ
« Reply #4 on: January 27, 2018, 01:00:05 pm »
So the package looks like the one in the link below but is marked '75'
http://p.globalsources.com/IMAGES/PDT/S1150212377/SMD-Ultrafast-Rectifier-Diode.jpg
« Reply #5 on: January 27, 2018, 05:37:39 pm »
see attachment thanks
Offline DTJ
« Reply #6 on: January 28, 2018, 01:29:22 pm »
Sorry, can't find it in any of my reference docs.
