Thanks Sean & MG. You gave me a bit more enthusiasm to dig deeper and actually I have a much better picture now. I'm sure that is a fuse. You can see a better pic (following post, '7610 PCB 1_ann_r.jpg'), on the top of the part it looks like it has an 'F' not 'O' and it is open circuit. The area of the circuit which it protects
is a MOSFET output stage. You can see this in the first pic. There are two
IRF6665 MOSFETs. They seem to be driven by a proprietary Epson chip. The fuse F1 does indeed connect to Q4 Drain. Unfortunately the G, S terminals are underneath these devices so it isn't straightforward to trace and test.
It seems like this pair of MOSFETs drives a resonant circuit of an inductor (with writing R33L on top) and C226. The circuit is near the connectors to the print head (underside, to right) so seems this is for the print head rather than a motor... not sure.
G-D resistance is about 80k. I'm looking to see if there is a D-S short but i dont think so. An important thing is to know if it is a fault on the driver or in the print head. If the latter, i think it writes-off the printer and obviously any time/money spend on the driver also wasted.
Instead of replacing the fuse, i think maybe I'll try powering the PCB with just the display module (not all the 30 or-so other connectors..), see if it gives same error
If it does, I can:
- probe the supply side of F1 to see what the supply voltage is
- see if there are Gate drive pulses
- replace the fuse with a power resistor that would limit the output current quite a bit, depending on supply voltage measured above
If not possible to test outside the printer:
- replace fuse with arbitrary value power resistor
Continuing:
- power up with print head disconnected
- see if the original error goes away
- measure the output developed over the inductor if possible
- measure current through the power resistor
- remove resistor and try with a fuse if above is not showing high current (should be low/zero with no load)
- connect print head
- bang!?
Any better ideas?
