Greetings,
I am looking for some guidance with replacing a IC chip that appears to be faulty. Specifically, it is TPS53515 chip and its size is smaller than anything I have worked on in the past. My thoughts are to remove the larger inductor first for better access but I was concerned about the adjacent caps and resistors flying away. For replacement, I was planning to use solder paste T5 at low air flow to mount replacement chip.
Any thought or suggestions on this?
Thanks!
