Author Topic: Newbie - Battery PCB Repair - Component Identification  (Read 2161 times)
Offline GriffoTopic starter
  • Country: hk
« on: September 13, 2019, 04:45:09 am »
Hi all,
Long time lurker of the forums and Dave's channel, lots of great info.  I now need some help...
Recently I started a project of fixing a 2014 Brammo Empulse R motorbike.  The battery was having various faults and making the bike unusable for the previous owner.  I'm very much a DIY person, love tinkering and love bikes so I thought I would grab it and have a go at repairing it.  I narrowed the fault down to a balancing issue.  The onboard charger stops charging if it detects one module out of limits, tries to balance the cells by bringing down the high cells then commences charging again.  The problem was that the high cell wasn't coming down so the charger refused to charge anymore.
The module out of balance was no 1 of 7 and after pulling apart the battery I found out why.  The battery has 4 internal heaters that are used for heating (obviously) and also for balancing when commanded to.  Due water ingress part of the module's controlling PCB had some corrosion and component damage which has stopped the heaters from working which is why the charger couldn't balance the pack.  I've cleaned up the corrosion with some vinegar which seems to have worked.  I now need to identify the damaged components and replace them and hopefully get this bike working again.
I've attached photos of the stages of me pulling apart the bike for those interested.
The bike before dismantling
834039-0
Disassembled
834045-1
7 battery modules
834051-2
Module 1
834057-3
Cover removed
834063-4
Corrosion on PCB
834069-5
Underside of the module showing all the pouch cells
834075-6
Top of the module with PCB removed.  You can see the plates used to connect the pouches in 4p9s config.
834081-7
Underside of the PCB
834087-8
After cleaning up the corrosion.
834093-9
edit: fixed up photos
« Last Edit: September 13, 2019, 04:48:10 am by Griffo »
  • Country: hk
Re: Newbie - Battery PCB Repair - Component Identification
« Reply #1 on: September 13, 2019, 04:52:58 am »
Below is a close up of the corrosion area.  The components in the red boxes are the ones I've identified as possibly being damaged and I'm trying to identify.
834102-0
I'm learning as I go with this one.  I'm open to all hints, tips, recommendations or abuse...
Thanks everyone for your help...
« Reply #2 on: September 13, 2019, 04:57:10 am »
Hi all,
(Attachment Link)
Welcome to the forum.
Nope, not nearly clean enough especially around C62.
Warm soapy water then flush with clean water or pop the whole thing in the dishwasher.
An old toothbrush can be good for cleaning PCB's.
Leave in the sun for a couple of days to properly dry.
« Reply #3 on: September 13, 2019, 05:05:29 am »
(Attachment Link)
L1 is an inductor and if it gives a small ohms value reading then it's probably OK.
My guess for C74 is a 10uF SMD tantalum and it can be tested with any reasonable DMM.
U24 will be the same as all the others in that row and we need the SMD code from from one of them to identify it.
Package looks like SOT23-5 and measurements can confirm that.
C62 is probably 0.1uF or 0.01uF.
Online fzabkar
« Reply #4 on: September 13, 2019, 05:29:13 am »
The capacitor appears to be a 100uF, 10V, lead free, solid tantalum type made by Vishay/Sprague:
https://docs-apac.rs-online.com/webdocs/1682/0900766b8168211c.pdf (page 3)
The date code, C7, decodes to July, 2012:
http://www.vishay.com/docs/40110/faq.pdf
Edit:
The "F" appears to denote the 893D or TF3 series. Both have a built-in fuse, while the TF3 has low ESR.
https://in.element14.com/vishay/tp3c107k010c0250as/cap-tant-100uf-10v-2312/dp/2629628
http://www.farnell.com/datasheets/2050130.pdf
« Last Edit: September 13, 2019, 05:45:13 am by fzabkar »
Online fzabkar
« Reply #5 on: September 14, 2019, 03:58:58 am »
  • Country: hk
« Reply #6 on: September 22, 2019, 05:18:33 am »
You guys are legends! Thanks heaps for the info.  I've been away with work and haven't had much time to look at it further.  I'll have a look at the info provided and try and take same better close ups.
I've managed to source some more battery modules from another bike that aren't working.  I should be able to grab the components off the PCB of those modules to fix this one.
I'll post updates when I get further info.  Thanks again!!
Offline Korbin Dallas
« Reply #7 on: October 18, 2021, 02:06:45 pm »
Reviving this thread in hopes of more info on what was found out.
I have a similar bike with a charging problem
Cheers.
