Electronics => Repair => Topic started by: citroen42 on January 02, 2025, 11:17:07 pm
Title: SMD Identification Help: ANSX 11
Post by: citroen42 on January 02, 2025, 11:17:07 pm
Hi All,
My Beolit15 has stopped charging the Li-Ion battery.
Opening up the unit is is clear that Q5 is burnt badly, see attached photo.
The SMD ID was barely visible but managed to identify it as "ANSX 11" (SOT-23), which is the same as Q4.
I've looked in various places but not able to identify the component, are any of you able to help working out what it is?
Thanks in advance
Brian
Title: Re: SMD Identification Help: ANSX 11
Post by: eb4fbz on January 02, 2025, 11:42:57 pm
AO3420?
Post by: citroen42 on January 03, 2025, 08:54:28 am
Thanks for the quick response eb4fbz!
Your suggestion makes sense and I've confirmed the behaviour via Q4.
Cheers
Brian
