Author Topic: How to unlock Level 2 calibration functions without 6-digit key?  (Read 184 times)
Offline augustaulrichTopic starter
Hello,
I recently acquired a Marconi (IFR/Aeroflex) 2024 signal generator. Everything seems to be functioning well, except for the AM modulation depth, which only reaches about 92% at full modulation. How can I access the "Level 2" calibration functions without the 6-digit key?
Offline George Edmonds
Re: How to unlock Level 2 calibration functions without 6-digit key?
« Reply #1 on: January 03, 2025, 11:02:25 am »
Hi
You cannot do so.
Send me your insruments serial number (rear panel) and it's ESN (display) and I will generate you an unlock code to level 2.  This unlock code is for your instrument ONLY.
G Edmonds
The following users thanked this post: voltsandjolts
