I have a part on a board which I suspect is a SPI eeprom, however I havent been able to find a datasheet. Its an 8 pin package marked as 2L508 2L805 and I believe it has WP on pin 3 ("WP"" is marked on the sikscreen on a test pad wired to this pin so that is a pretty good hint!).
The chip is storing EDID information on a laptop LCD panel and I'd like to update the contents but need to firstly confirm the model to check that my programmer supports it. I''ll possibly have to remove it from the board to program it. I believe that only the clock and MISO are connected through to the laptop - thus when attempting to reprogram it using from the computer, the information is not stored as MOSI is not wired outside of the panel (there is a test pad on the board for this pin that they likely use to program it in the factory).
Any thoughts what it might be? I was thinking perhaps 25L080 but that is a lot larger than necessary for EDID. 25L010? That will be my first try if I cant identify it before I try program it.
