Author Topic: SMD Marking PAYI  (Read 707 times)
Offline 2XTopic starter
  • Country: gr
SMD Marking PAYI
« on: January 18, 2024, 08:45:25 pm »
Hello,
I have an smd component with 5pin but I found in two different datasheet of the same company (Texas Instruments) this marking "PAYI"on two different part numbers. I can't understand which part numbe is the right. Also at the internet I found pictures with this marking at both part numbers. The only difference that I found is that some letters have below or under horizontal bars. Does the bars mean something?
TPS2816DBVR
https://www.ti.com/lit/ds/symlink/tps2819.pdf?ts=1705563023219&ref_url=https%253A%252F%252Fwww.mouser.in%252F
TPS2819QDBVRQ1
https://www.ti.com/lit/ds/symlink/tps2819-q1.pdf?ts=1705587616752&ref_url=https%253A%252F%252Fgr.mouser.com%252F
Offline Vovk_Z
  • Country: ua
Re: SMD Marking PAYI
« Reply #1 on: January 18, 2024, 10:36:13 pm »
2016 has PAAI code and 2019 has PAYI code as seen from first datasheet. Second dataseet shows codes only for 2019 and 2029.
« Last Edit: January 18, 2024, 10:40:13 pm by Vovk_Z »
The following users thanked this post: 2X
  • Country: gr
« Reply #2 on: January 19, 2024, 07:05:57 am »
What is the right part number you think?
Offline fzabkar
« Reply #3 on: January 20, 2024, 07:28:33 pm »
I think the bars denote a date code.
Your datasheet shows PAYI for TPS2819QDBVRQ1 and PAYQ for TPS2829QDBVRQ1. However, TI's lookup page produces confusing results.
https://www.ti.com/packaging/en/docs/partlookup.tsp?partmarking=payq
https://www.ti.com/packaging/en/docs/partlookup.tsp?partmarking=payi
https://www.ti.com/packaging/en/docs/partlookup.tsp?partmarking=paai
I think you should choose TPS2819 if your circuit requires Vdd on pin #1, or TPS2829 if pin #1 is NC.
« Last Edit: January 20, 2024, 07:39:39 pm by fzabkar »
