The good news is that it arrived and the display had the odd glitch or two, but opening the beastie (what fun that is), and removing/reseating the connector from the main board to the display (and every other connector in sight), plus clearing out the dust seems to have fixed it (fingers crossed). I tried to up-hack to TDS3064B after upgrading firmware to 3.39 but didn’t work using Keysight VISA utility . Couldn’t get TekVisa to play
A 9 pin null modem cable just arrived and I connected to the scope using Putty (9600,N,1 RTS/CTS) with local echo turned on:
*IDN?
TEKTRONIX,TDS 3014B,0,CF:91.1CT FV:v3.39 TDS3GV:v1.00 TDS3LIM:v1.00 TDS3FFT:v1.00 TDS3TRG:v1.00
password pitbull
mconfig tds3064b
Powered off, and then:
*IDN?
TEKTRONIX,TDS 3064B,0,CF:91.1CT FV:v3.39 TDS3GV:v1.00 TDS3LIM:v1.00 TDS3FFT:v1.00 TDS3TRG:v1.00
Checking with an SG504 shows the 3db point into 50 ohms (1Vpp in displayed .707V) is at 760MHz.
D.
