Author Topic: SMD Regulator part number  (Read 1441 times)
Online McBryceTopic starter
« on: June 20, 2017, 12:47:43 pm »
     I've been given a PCB to repair that has been subjected to physical damage. One of the parts I need to replace, which I suspect is a voltage regulator has the marking SQ3GE. It's a SOT23-5 device, but endless interweb searching doesn't turn anything up. Does anyone happen to know what this part is?
McBryce.
Offline bktemp
Re: SMD Regulator part number
« Reply #1 on: June 20, 2017, 03:21:05 pm »
Do you know the output voltage?
R1122N341B has SQxx marking code.
http://www.e-devices.ricoh.co.jp/en/products/product_power/mark/ME-R1122N.pdf
There is also NCP346SN1 with marking code SQZxx.
« Reply #2 on: June 21, 2017, 06:59:57 am »
Unfortunately not. I think it was probably 3.3V, but the main (only) IC has it's number filed off, so it's not that easy to say.
McBryce.
