Author Topic: Looking for NEC PS2561-W opto-isolator equivalent  (Read 7546 times)
Offline Agent24Topic starter
« on: September 28, 2014, 11:03:43 pm »
I need a new NEC PS2561-W opto-isolator, having accidentally broken a lead off one. The W represents the CTR (current transfer ratio) which in this case is 130 - 260%
I can't find any PS2561 anywhere in New Zealand, let alone the W version.
Another problem is this Opto has Vceo of 80v, and the maximum I can find in Farnell or RS is 70v.
Does anyone know of a suitable replacement that isn't made from unobtainium? - or even someone who has some and would be willing to sell me one?
Offline David_AVD
Re: Looking for NEC PS2561-W opto-isolator equivalent
« Reply #1 on: September 29, 2014, 12:30:34 am »
Try the parametric filters on the Digikey web site to narrow down your list.  It should have filters for Vceo and CTR at least.
« Reply #2 on: September 29, 2014, 02:40:09 am »
Thanks, didn't think of that since Digikey doesn’t ship here (cheaply) but it did lead me to this (the only) one: http://nz.element14.com/sharp/pc817x2nsz0f/optocoupler-phototransistor-5kv/dp/2420048?Ntt=PC817X2NSZ0F
(Aside from the PS2561 itself and the PS2501)
Unfortunately I don't know if it will be suitable, it has lower diode forward current rating (50mA vs 80mA) also Veco is 6v vs the 2561's Veco of 7v.
Online MarkL
« Reply #3 on: September 30, 2014, 01:26:55 pm »
Here's someone selling the W version with VDE rating on ebay:
  http://www.ebay.com/itm/261351421896
There may be others.  You can also search for "NEC2561" (some sellers are just reading the top of the chip).
« Reply #4 on: October 04, 2014, 11:25:00 pm »
Thanks, I did actually see those before, but I am very wary of Chinese sellers. Maybe I will risk it if I can't find anything else.
