Author Topic: SMD SOT23-5 Please help me identify component  (Read 514 times)
Offline radczaTopic starter
« on: December 07, 2020, 11:26:48 pm »
HI.
Can I please for help in identifying the following SMD component? Package is SOT23-5. Marking is bPCGD . Probably is voltage detector or regulator but I dont know the ecaxt parameters. It is a component of mainboard IP camera YI YHS3017.
I add photos of the mainboard. Pinuot 3 is connected to a nearby coil, pinout 2 is ground, pinout 4 is voltage from power supply (VIN +5V) and pinout 1 is probably VOUT. I`ve looked in many catalogs but it is probably a unique label of the manufacturer. I've been looking for this information for several days. I wonder what is means small letter "b" on the marking? Its means country of production or manufacturer designation? Thank for your help!
1125332-0
1125336-1
1125340-2
1125344-3
Online wraper
  • Country: lv
Re: SMD SOT23-5 Please help me identify component
« Reply #1 on: December 07, 2020, 11:34:05 pm »
Looks like buck converter.
Offline fzabkar
« Reply #2 on: December 07, 2020, 11:56:11 pm »
I suspect that pin #5 is the feedback pin. If so, then there should be two resistors connecting to this pin -- one to ground, the second to Vout. Measure the voltage at this pin. That should make it a little easier to find the IC. A typical feedback voltage is 0.6V.
