Thank you, Michel.
I'll look at this route with oscilloscope.
But my output stage is significantly different from yours. Look at the picture.
I have the first two MMICs labeled H1 and the third, which differs in the case, also labeled with H1.
This third, I think it's like your SFH-189.
And what are the first two? And maybe it does not matter now!
Also, I noticed that for all three amplifiers there are general purpose PNP transistors for polarization (BSP31), whose configurations at first glance is exactly the same.
For the first two, I'm sure.
However, measured with ordinary DMM, the difference on the pins B, E, and C is drastically different. For A1, C-E=39 Omhs, independently of the polarity of the DMM. BSP31 for A2 has about 55kOhms.
Below, on side B, there are two op amp TL074. These OP amps probably controlled these transistors. Thay have the same configurations. But they, also have different ohmic values!
I think that one TL is bad, since I have checked the transistor.
I'll be back when I get this op amp.
Another thing, do you know which component is in white plastic, marked with W1. Mixer, combiner ...?
I can not read the label on your picture.
73
Aleksandar
