Author Topic: SMIQ 03B upgrade firmware error  (Read 1115 times)
Offline no_oneTopic starter
  • Country: cn
« on: October 15, 2022, 03:19:10 pm »
Hi everyone,
SMIQ 03B using WinFlashPro to update the firmware will stop at half, as shown in the picture。
sometimes it will prompt “Program File = SM3_1”. and will stop here。
I am using RS232 to update。
what is the problem?
« Last Edit: October 15, 2022, 07:24:41 pm by no_one »
Offline drhex
Re: SMIQ 03B upgrade firmware error
« Reply #1 on: October 17, 2022, 10:04:27 pm »
The flashing software is pretty sensitive to its environment, had to buy an old laptop with serial port and install win2k to get it to work reliably.
  • Country: cn
« Reply #2 on: November 11, 2022, 04:57:56 pm »
Thanks Reply!   What is the difference between USB to RS232 and built-in RS232? The update is half stuck, WinFlashPro will show "Not Responding"!what is the reason?
Offline Jarek
« Reply #3 on: November 11, 2022, 08:39:17 pm »
Offline edpalmer42
« Reply #4 on: November 11, 2022, 09:13:52 pm »
Officially, RS-232 voltage levels must be +3V or higher and -3V or lower.  But most USB to RS232 converters use TTL/CMOS levels in the range of 3 - 5 volts and ground.  Most equipment accepts this, but some get confused.  I don't know if R&S equipment gets confused, but that's the first thing that I would check.
Ed
