hi.
I'm trying to repair this 48v poe power supply and I was hoping you could help me figure out the problem.
It should have 48v out put voltage but it only has 4 up to 6 volts. I tried replacing a smd capacitor and the optocoupler , these two were bad components but the problem is still there. after looking around more I found that the high voltage side is working just fine and the problem is on low voltage side. specially the feedback circuit. because when I short-circuit the output of the optocoupler for 1-2 seconds I get my 48v back! also on the input of the optocoupler I don't get any voltage. is that normal ?
my second suspect is the shunt regulator but I'm not sure and don't have spare parts right on hand to test it.
please help me if you know what I should do next .
here are the pictures of the board :
