Author Topic: SMPS based on TOP232  (Read 3578 times)
Offline masterx81Topic starter
« on: March 18, 2020, 08:06:14 pm »
Hi! I'm repairing an smps based on the TOP232 controller.
mouser.com/datasheet/2/328/top232-234-1512691.pdf
The schematic is almost the same as the suggested in the PDF.
I've had to change the controller, a 220ohm resistor between the 230v rectified line (i think that's for limit the current), and an opamp after the transformer. The sensitive things are safe as after the smps there was a 3.3v ldo (that is ok). Also the transformer was burnt, so i've had to rewire it, as i wasn't able to find a valid substitute. For the primary side i wasn't able to measure the number of turns, as was an unique block of molten things, but i was able to measure the total lenght of the wire, with a little approssimation, i think that is enough to make it work. On the secondary side i was able to count the turns of the 2 windings.
Now, the smps starts ok, i get on the "control" winding 17.5v (there is a 20v tantalum cap, so i think that is quite ok), but on the  5v line i have near 4.3 volts (must be 5v). The strange thing is that when i turn off the supply, when the >300v line starts to drop due to capacitor discharge, the smps start working perfectly, giving a perfect 5v output, until the voltage drops too much. On the 220ohm resistor with main line connected i have a voltage drop of near 1.3v, when the 300v line start dropping it goes to a 2.5v drop (as the logic is working it consumes more current).
What can cause the problem? The winding ration of the transformer? Maybe i can do a better thing, isolate the onboard smps and put a 5v external smps, buth would be nice to make it work....
Thanks!!
Offline aqibi2000
Re: SMPS based on TOP232
« Reply #1 on: March 18, 2020, 10:37:34 pm »
20V cap on a 17.5V line is not good practice at all.
Did you measure the peak amplitude using an oscilloscope or just going by the RMS value your multimeter is giving? Because you will have 17.5*1.41 = ~25V peak
Tinkerer’
« Reply #2 on: March 19, 2020, 01:18:21 am »
I've measured after the rectifier diode, where is the smoothing cap.
When i remove the power, and the switching start working normally (during the main filter capacitor discharge period), that voltage remain the same.
Offline Circlotron
« Reply #3 on: March 19, 2020, 02:03:29 am »
Sounds like it is going into overvoltage shutdown mode when the DC input voltage is too high. The example circuit shows a 3M3 resistor from DC input to the M pin on the IC. Is that the value you have? Too low a value would make it shut down at normal DC input voltage.
Offline wraper
  • Country: lv
« Reply #4 on: March 19, 2020, 02:10:25 am »
It's completely not OK and asks for trouble. Even if it was electrolytic, it would be marginal but tantalum caps should be derated by at least 50%, preferably 70% for better reliability. You can sort of use them at 80% of rated voltage but failure rate will be abysmal. And if there is enough current supply, wait for firecrackers.
Offline wraper
  • Country: lv
« Reply #5 on: March 19, 2020, 02:26:23 am »
There shouldn't be 17.5V BTW, schematic in the datasheet has 10V capacitor (page 14).
« Reply #6 on: March 19, 2020, 07:41:19 am »
Look at figure 26, the control winding can produce 15v.
I think that 15v can be the right voltage, i not know why i get 17.5 (actually 17.2) as i have mantained the same turns of original transformer. In this case i think that is important to mantain the same turn ratio of the 2 secondary windings, but i've maintained it. I not think that 17.2 can harm the smps ic as from the schematic there is some sort of internal limiting. Maybe the cap is a bit overstressed, if all other things are ok i change the cap with a different one. But before i need to find why it's not working
« Last Edit: March 19, 2020, 07:46:55 am by masterx81 »
« Reply #7 on: March 19, 2020, 07:43:53 am »
@Ciclotron, I'll check it, thanks!
Checked! Two 1.8m resistor in series, both ok.
« Last Edit: March 19, 2020, 08:05:08 am by masterx81 »
« Reply #8 on: March 19, 2020, 09:42:17 am »
Just one curiosity: What can cause an incorrect wiring direction of the windings?
All other things seem ok, on the secondary side if i power the device with a separate supply i get a 150ma power consumption on the 5v line, and seem in line with the sizing of the core, on the primary side all components seem ok. So i can only think that the rewinded transformer can have some problems. But why it works well when the power supply drops? The diameter of the enameled wires was checked several times (with centesimal micrometer). Maybe i have choosen a little smaller primary wire, so at same wire lenght i have more turns, and the smps ic working at lowest duty possibile. But this ic can work  from 200vdc to 375vdc (by now i am powering it with 320vdc), so must have quite a wide range of duty available. I not think that i was able to go so much off. But i can check with scope the duty that is working.
Next thing i try to power it through a variac and see if it works well with lower voltage...
Variac testing done. If i start with 230vac then drop to 130vac, i get a clean 5v. If i start at 130vac, it does not neither start (as expected).
What's going on???
« Last Edit: March 19, 2020, 11:42:25 am by masterx81 »
Offline PKTKS
  • Country: br
« Reply #9 on: March 19, 2020, 10:55:55 am »
First time I see such mixture of things into a single IC.
IT LOOKS LIKE MUCH MUCH MORE A TYPICAL RCC ...
than the advertised forward...
It made me wonder what kind of typical wave you
may have on the switcher mosfet...
So considering it more RCC it may have the resonator
capacitor mismatched since you rewired the primary coil
RCC things must be matched to proper resonance..
otherwise they go haywire
long guess
Paul
p.s/: actually I remember some time ago from these folks TOP221
being somewhere advertised as innovative  "QuasiResonant"  thing...
may be some published slides presentation of that...  google for it
« Last Edit: March 19, 2020, 11:02:08 am by PKTKS »
Offline Circlotron
« Reply #10 on: March 19, 2020, 11:24:27 am »
Maybe add a bit more?...
Seriously though, maybe the controller is just out of spec and a bit more resistance might do the trick. At least it's easy and cheap to try. Just divide the max rated voltage by the max voltage it actually runs at and multiply the resistance value by that figure. Example... max rated = 400V, actual max = 275V so (400/275) x 3.6 meg = 5.236 meg.
« Reply #11 on: March 19, 2020, 11:58:54 am »
@PKTKS
I've seen a similar thing in a active pfc smps of an lcd tv, but had a big polyester cap that was resonating with the transformer (and was an hell to repair!). In this circuit the only capacitor that i have on the primary side is the c5 on the pdf ref. page 16 figure 26, and seem part of an rc filter. The other caps are smoothing caps on vcc and after the rectifier diode.
I've also edited the previous post with the result of playing with the variac...
@Ciclotron uhm, that multifunction pin is something strange (a lot of functions for a single pin!), eventually i can try to put it to source and disable all the protections, to see if it works.
PS: I have the DIP package, so i not have the FREQUENCY pin
« Last Edit: March 19, 2020, 12:02:01 pm by masterx81 »
« Reply #12 on: March 19, 2020, 12:08:01 pm »
If i well understand, the Multifunction pin now is set in UV, OV, and DCmax limits, as per figure 14. Maybe at full voltage i'm hitting DCmax limit as i have LESS turns on primary side as the original transformer?
Offline PKTKS
  • Country: br
« Reply #13 on: March 19, 2020, 02:07:51 pm »
@PKTKS
Yes I am also puzzled with so many "functions" on a single pin
they sacrifice a clean design for that..  WTF?
47u is too much for frequency compensation...
as far as I can guess..  by position I would guess
but that value is far too much.
Anyway it sure have internal things for
frequency compensation and stuff.
Guessing the inductance value is out of
previous calculation would justify a lot of things
playing a bit those unique components capable
of tweaking the steady state would be my shot.
Paul
Offline wraper
  • Country: lv
« Reply #14 on: March 19, 2020, 02:10:32 pm »
Are you sure some winding isn't connected backwards?
You said primary winding was completely toast. So I wouldn't be surprised you did it  wrong.
« Last Edit: March 19, 2020, 02:12:21 pm by wraper »
« Reply #15 on: March 19, 2020, 02:49:09 pm »
No, i'm not sure. That's why i was asking. But as the signals are rectified right after the transformer, it can cause problems? How i can know how was wired?
I think that the typical application circuit is correct, but the dot marking has always puzzled me. If i remember well when i've wired it i've used always the same direction for primary and secondaries. I think i can confirm stimulating it with the function generator
« Reply #16 on: March 19, 2020, 02:55:07 pm »
Paul
My cap is 47uF too... strange that a "tuned" component have the same value of the reccomended schematic.
The resistor is low value, can explain why the cap is so big
« Last Edit: March 19, 2020, 02:56:48 pm by masterx81 »
Offline wraper
  • Country: lv
« Reply #17 on: March 19, 2020, 03:10:50 pm »
It's rectified in one direction only. It's not like you have nice symmetric sine on the output, so it does matter a lot in which direction windings are connected in regards to each other.
Open the datasheet and there you can see direction (dot) of each winding. Or try connecting primary winding backwards and see what happens.
« Reply #18 on: March 19, 2020, 03:36:31 pm »
As i can understand the dot is the polarity, but how i can know how correlate it with wiring direction?
Let me understand, the polarity is important because on the primary side there isn't a push pull transistor configuration, but only a pull down to gnd, so we have only "power" on one half of the wave. That's why we have only a one diode rectifier on the output. But if it's badly wired, i think that i get almost any current from the secondaries.
I am wrong?
Offline wraper
  • Country: lv
« Reply #19 on: March 19, 2020, 05:34:25 pm »
Consider dot as start of the winding considering all of them are wound in the same direction.
https://en.wikipedia.org/wiki/Flyback_converter
The most important part:
When the switch is closed (top of Fig. 2), the primary of the transformer is directly connected to the input voltage source. The primary current and magnetic flux in the transformer increases, storing energy in the transformer. The voltage induced in the secondary winding is negative, so the diode is reverse-biased (i.e., blocked). The output capacitor supplies energy to the output load.
When the switch is opened (bottom of Fig. 2), the primary current and magnetic flux drops. The secondary voltage is positive, forward-biasing the diode, allowing current to flow from the transformer. The energy from the transformer core recharges the capacitor and supplies the load.
« Reply #20 on: March 19, 2020, 06:32:55 pm »
Ok, got it..but if the windings of the transformer are wrong, the diode on the secondary side never goes in conduction, as the flyback has no positive part. So no voltage on the secondary. Instead i have voltage on both secondaries, and when it work it can source 150ma of current. It's impossible if the polarity of the windings is wrong. And as told, i'm quite sure to have wound them all in the same direction.
In any case, thanks, because i've (maybe) understood the difference from a normal transformer and a flyback smps transformer  :-+
Offline wraper
  • Country: lv
« Reply #21 on: March 19, 2020, 06:37:38 pm »
Totally wrong assumption. Doesn't it look familiar? https://en.wikipedia.org/wiki/Forward_converter
« Last Edit: March 19, 2020, 06:39:39 pm by wraper »
« Reply #22 on: March 19, 2020, 07:00:57 pm »
Ok. Now i think that i've not understood so well  |O
So, actually is not working by flyback, the core doesn't store energy but passes energy to the secondaries (like a normal transformer?). But how it can generate a negative part so strong to source 150ma of load? And if the negative part is so strong, why not recover it?
I've repaired smps, but actually never knew the magic inside the core of the transformer  :palm:
Offline wraper
  • Country: lv
« Reply #23 on: March 19, 2020, 07:09:29 pm »
It works but half-arsed if it was not designed properly as forward converter. Which correlates with your case.
« Reply #24 on: March 19, 2020, 07:15:20 pm »
As now that the core is already glued, can i test it with a waveform generator and checking with a scope it's output?
But why on the top232 datasheet the secondaries are polarized inverted from the primary?
Offline wraper
  • Country: lv
« Reply #25 on: March 19, 2020, 07:17:31 pm »
Because it's how flyback converter works. If it's opposite, you get forward converter.
« Reply #26 on: March 19, 2020, 08:03:18 pm »
So, that's why you was suggesting to simply invert the primary winding. Maybe the controller increase the dc a lot for try to have enough "negative part" of the flyback to reach the 5v.
Buh how recognize on the fly a flyback converter from a forward converter? Looks so similar.
Offline wraper
  • Country: lv
« Reply #27 on: March 19, 2020, 08:09:31 pm »
The simplest would be according by PWM controller model.
« Reply #28 on: March 19, 2020, 08:18:27 pm »
Perfect, was hard, but (maybe?  :scared:) i've learned something  |O :-DD
If it's a flyback, i'm sure that the the windings are wrong as i've wound them all on the same direction.
Try to invert the primary tomorrow.
Really thanks!!
Offline wraper
  • Country: lv
« Reply #29 on: March 19, 2020, 08:20:28 pm »
TOP232 is flyback controller. It's not supposed to work as forward converter.
Offline Circlotron
« Reply #30 on: March 20, 2020, 03:11:27 am »
A flyback converter has no filter inductor. The rectifier diode on the output side feeds straight into a big capacitor. This is because the transformer secondary winding of a flyback converter is a current source, with a forward converter it is a voltage source.
Offline wraper
  • Country: lv
« Reply #31 on: March 20, 2020, 03:21:04 am »
You need to be aware that flyback often has inductor as well. Just a bit later in the circuit for noise filtering purposes. So simply presence of inductor does not mean anything unless you checked how it's actually connected. Though inductor in forward converter most likely will be larger in size.
« Last Edit: March 20, 2020, 03:25:53 am by wraper »
« Reply #32 on: March 22, 2020, 08:41:48 pm »
Inverted the primary and now i have 15v on control line and 5v on the output. Perfect!
Thanks for the help and for the expalaination on how works smps transformers!
EDIT
Still something wrong... it start, i have clean 5v and 15v on the outputs, then after 10/15 seconds the output goes down. If i power off, it start working ok during the main filter capacitor discharge like before... it start working when voltage goes down at near 200v. Seem temperature dependant, if i do it when cold seem work longer than doing several tries. I not see nothing overheating
« Last Edit: March 22, 2020, 09:02:35 pm by masterx81 »
The following users thanked this post: Circlotron
« Reply #33 on: March 23, 2020, 10:59:30 am »
Leaving it connected it works for 10/15 sec, then turn off, after few seconds start working back for 5 sec, and so on. Seem a protection triggering. It's not an overtemperature.
I attach the waveform of the primary side. The waveform seem good (no strange duty cycle, in the 29% region with 220vac input). I not see any appreciable variation in the waveform before shutting down.
With 180vac i have a duty of near 34% and it does the same thing (on-off-on-off etc).
I attach also the waveform when it's not working...
What sort of protection can be?
Thanks!
Offline PKTKS
  • Country: br
« Reply #34 on: March 23, 2020, 11:17:46 am »
**IF**  this was your first post on the subject...
with just the waveform ...
asking for guesses...
I would just say:
- by the waveform - THIS IS AN RCC (not a forward converter)
- and pretty much RCCs gone haywire with bad parts...
- a minor aged component or with different/changed values for  RCC steady state....
if  I was just looking that  waveform and ignoring the rest...
go figure why this chip behaves like RCC...
Paul
« Last Edit: March 23, 2020, 11:19:36 am by PKTKS »
« Reply #35 on: March 23, 2020, 11:33:06 am »
Seem a flyback converter (for sure as the primary of the transformer is out of phase from the secondaries, also in the pdf).
The smps ic have really few components around it. I attach a photo of the d**n thing.
« Reply #36 on: March 23, 2020, 11:39:24 am »
 D18 is the rectifier of the 5v output, c39 is the 5v smoothing cap, u2 optocoupler,  d17/c36 rectifier of 15v control voltage,  c41 and r56 seem an rc filter (not tuned, same values of the pdf), d19/d20 as per pdf. C35 seem a 300v smoothing cap placed near the smps. C42 smooth the input voltage of the smps ic.
« Reply #37 on: March 23, 2020, 02:51:26 pm »
I've checked the pdf and i've not seen any requirement about needed inductance, and neither nothing about capacitors to "tune". But from pdf the switching frequency must be typ 124-140khz, while i've measured around 107khz.
Offline PKTKS
  • Country: br
« Reply #38 on: March 23, 2020, 03:27:09 pm »
They all do.  Implied on design of flybacks.
But we have today a off-the-shelf  ready numerated coils to choose.
Another shot:
- using that TL431 transconductance  error amplifier...
- Try to play the feedback loop current to voltage ratios...
Eventually you may have luck tuning the FB loop itself
for steady state operation at some load ranges.
Paul
« Reply #39 on: March 23, 2020, 07:17:22 pm »
Oscillator and Switching Frequency
The internal oscillator linearly charges and discharges an
internal capacitance between two voltage levels to create a
sawtooth waveform for the pulse width modulator. The
oscillator sets the pulse width modulator/current limit latch at
the beginning of each cycle.
The nominal switching frequency of 132 kHz was chosen to
minimize transformer size while keeping the fundamental EMI
frequency below 150 kHz.
The internal oscillator is not tied to the inductance. Is linearly charged and discharged, i think by an internal resistor.
The feedback loop has nothing strange or that can be tuned. Filters and resistors, and the optocoupler. And in any case the voltages of the feedback are good (5v and 15v).
Really, i think to remove that damn thing and put an external trasformer!
« Last Edit: March 23, 2020, 07:20:21 pm by masterx81 »
Offline shakalnokturn
« Reply #40 on: March 23, 2020, 07:39:59 pm »
Have you checked transformer's temperature itself?
Primary winding too thin?
« Reply #41 on: March 23, 2020, 08:28:06 pm »
The original winding was measured with a precision micrometer... i've checked by hand  and with an infrared gun and nothing more than 35*c.
« Reply #42 on: March 23, 2020, 08:58:54 pm »
New TOP232 came from a reliable source?
« Reply #43 on: March 24, 2020, 12:10:39 am »
Ehm, not. Ebay or aliexpress... i try to find a different smps ic...
« Reply #44 on: April 01, 2020, 03:42:33 pm »
Replaced the smps ic with one new of the same batch, ad it works. The temperatures are low. All seem ok.
Thanks to all for the help!
I've lost some time but i've learned a lot of things  :-+ :-+
« Last Edit: April 01, 2020, 03:50:26 pm by masterx81 »
