I have a small "wall wart" 15V 600mA switchmode power supply. It measures exactly 15 volts output with no load so I at first thought the problem was with the equipment (a TV modulator) that it powers. However, as soon as I attach even the smallest load (drawing only a few milliamps), the voltage dives and no current is produced.
One interesting note: if I cycle the input power on/off many times, it will sometimes get into a mode where it works, and it stays working (for months) until the mains power goes out.
The unit initially failed after a city-wide power outage. However, that may be a red herring because the unit may have been degrading/failing, and the problem was only exposed when it had to restart.
The circuit is extremely simple because it uses a THX203H controller that does most of the work. There is no MOSFET power transistor. I've attached the reference design for this chip at the bottom of this post. My power supply is very similar to that design.
Given that it works about every 40-50 times it is plugged in, I suspect the capacitors. There are three electrolytics on the input (10-10-47) and two electrolytics on the output (680-100). They do not appear to be swollen, bulging or leaking. I do get a capacitance reading in-circuit, but as is often the case, it doesn't match what is on the cap label. The diodes all check out OK. I only casually checked the optoisolator, but it appeared to be OK. The input fuse is obviously OK or I would never get the 15 volt open circuit reading at the output.
I guess I should just pull the three input capacitors and see how they test out of circuit, but I thought I'd first see if anyone had a few suggestions.
