Hi ,
I'm repairing an older modular SMPS at the moment from the ASTEC company whic is now known as Artesyn Embedded Technologies.
The SMPS is a modular rack with 2 slot occupied with single output 15V DC units and 1 slot occupied with a +5V dual output.
I'm not an SMPS expert but I think it is using a kind of half bridge topology. The module itself converts 380VDC that was rectified and boosted from the 120VAC in the main rack to the required DC output (5V in my case).
The +5V module is dead, no output. I checked the usual ( output diodes, filter caps, switching mosfets, bridge rectifier .....)
I narrowed down the problem to the Pwm controller. The pwm controller is UC2825DW from TI. There is no output waveform on the controller. Vref is good at 5.1V and vcc is good at 17V.
What I don't get is that while troubleshooting, I accidently shorted pin 14 which is OUTB of the smps to VCC and the supply started. I confirmed this multiple time. If I force a voltage on the output pins of the pwm controller the switching action will start and the power supply works just fine.
What I don't understand is why is this so and what could be the problem? A bad component in the start up circuit locking the controller? A bad chip? I have two of these broken SMPS with exactly the same behavior.
Any ideas or help would be welcome. It is a complex PSU and I don't understand all the circuits for now.
Thanks
