I was presented with dead a LED PAR from one of the better Disco Dave manufactures of such equipment.
However, unlike the the big boys in the world of entertainment lighting they don't (or won't to me), supply schematics.
They will sell me a new power supply for $140++, except they will not have stock for another 2 months. Must be a common fault...
Anyway the patent is a '24V 4.16A 100W' very basic looking SMPS, of a small non standard size.
It presents the following symptoms:
Main fuse and PCB fuse were intact.
Q1 - Mosfet 26NM60N - Shorted
RS1 - 0.22Ohm 1% - Open (1MOhm)
D2 -
(Cooked cannot read) - Shorted
C4 - 3A332J Capacitor - Cooked by D2 (.96uf!)
R4 - 10 Ohm (?? Print missing from mid digit) - Open
U1 - SO8 - Top vaporized
I tested the unit on my bench supply and it appears to work fine, drawing 2.8A at 24V on full white.
The main cap appears to charge when plugged into the mains.
I fed 24V back into the output and the resistance across the optocoupler dropped at around 24.3V, so I assume that part of the supply is OK.
My main problem is the SMPS Controller IC has blown it's top, and I cannot find the remains! So I know know what to replace it with. So I will open that question up to the combined knowledge of the EEVBlog.
Below are the front and back of board, there is also a heatsink which wraps around the top of the PCB:
