Thanks for the comments so far.
Remembering that I'm trying to get tips and tricks to improve my success rate in switch mode repair. I posted the ccfl circuit just to have a specific example to discuss, so let me comment and respond:
CAPACITORS: My experience has been that electrolytic caps are the cause of general circuit failure more than half the time. However, in the case of switch mode failure, that hasn't been true. I always check any electrolytics for bulging and then in circuit esr or shorting, but other than a few tantalum caps, I seldom find other types of caps with any problems. So in smps repair I seldom find caps that need replacement, unless I find a problematic electrolytic visually or with in circuit testing. Do you agree?
No.
Yes commonly there are visual signs that caps are failing but this is often not the case. Degrading output caps not only result in high output ripple as if their leakage is severe they add additional current load to the supply and unless there is current sensing can overload the supply possibly resulting in catastrophic failure. With a SMPS like the topic of this thread the lack of current sense would concern me and I believe this unit and its later burn in failure is a good example of needing an infrared camera to assist finding problem areas before failure.
Back now to SMPS caps I have seen fail:
Primary side bulk cap: uncommon, normally no problem.
SMPS controller IC VDD bulk storage caps: common. These typically are ~20-50 uF and not low ESR. They primarily store and smooth the flyback supply to the IC. They drift low in value and go high ESR where they fail to do their job properly and prevent the SMPS IC from starting.
Output caps: Just nominal value checks generally disclose them failing however ESR checks are also required to confirm they are sound.
UPRATE VOLTAGE RATINGS: These are typically failures of devices that have worked for years, then my repair fails within days. Possibly increasing the voltage rating would help prevent the once a year spike failure. But since it fails almost immediately isn't it likely that there's another damaged component causing that second failure? I'm anyways concerned about changing or substituting out an original component. Do you often upgrade components when doing an smps repair or use original spec parts?
Typically matched to OEM spec however with MOSFETs real care is required to do this well however modern FETS can offer lower gate capacitance and therefore reduce risk of Miller effect. Google it.
In general no substitution is done without careful comparison between OEM datasheet and substitution part datasheet.
REPLACING TESTING CONTROL CHIP: The second failure always seems to involve a direct short through the switch FETs. Like the dead time wasn't long enough and both switches were on at the same time to short the rail and let out smoke. Do smps control chips fail that way? Do you usually test the control chip? If so, how? Do you replace it as a matter of course? Or do you think it's usually another component causing my problems?
Checking IC operation is not difficult but you do need the datasheet for UVLO and VDD specs.
All you need is a PSU with sufficient output to exceed UVLO and a scope to check the output drive to the MOSFET and this is done WITHOUT mains power to the SMPS.
After catastrophic failures there is no telling what damage spikes may have done to the IC so it is best to replace it.
As the SMPS in this thread is working at LV and its output is via a pulse transformer to the HV section it is safer to measure than a SMPS IC operating in the HV section where great care need be taken with all measurements.
Still, we must always identify if circuit Gnd is mains Gnd or an elevated value if we are to use a scope anywhere on a SMPS and it's safer to have a differential probe for SMPS work.
As I mentioned earlier in the thread IC datasheets and 'typical application' circuits are of great assistance to understanding SMPS.
