I'm trying to repair an LCD monitor with a bad power supply. It's a fairly simple SMPS, with 5 V and 12 V outputs. It uses a UC3842 IC, and a single TO-220 FET.
I get nothing at all on the secondary side. The primary has a steady voltage across the main capacitor, but the low voltage supply for the IC seems to pulse between 0 V and 16 V. I don't have an isolation transformer, so I can't put my scope on it. Clearly this is the problem, but I don't know how to fix it. I've read some guides which say to test the zener diodes, but how can I test them when I don't know what value they should be?
The power resistors all seem fine, as do the ancillary diodes. Everything looks fine, too.
It looks like someone had a go at fixing it previously. There are some scorch marks on the monitor chassis near the secondary, and the filter capacitors have been replaced, so I'm guessing the old ones blew up from the plague.
Any suggestions?
