I'm trying to fix the power supply of an LCD television. When I first plugged it in, it went *poof*, letting some magic purple smoke out, and blowing the fuse. I replaced some FETs, diodes, the bridge rectifier, and the series NTC resistor. There's still a short somewhere though, and I can't find it.
A light bulb in series with the mains glows at full power, but even when passing 100 Watts through the shorted component, nothing heats up save the NTC. The voltage on the main caps reads only a couple volts at this point.
I'm not sure what to try next. The rectifiers seem fine, along with everything else I test. I know a couple secondary caps are bulging, but they aren't likely to cause these problems. Any ideas?
