Author Topic: SMT marking AQT B A/D  (Read 817 times)
Offline NeoxyTopic starter
  • Country: si
« on: March 15, 2023, 01:30:40 pm »
Hello everyone,
After a lot of searching on the net and even ChatGPT I cannot find a component that has the marking AQT. After some reverse engineering I concluded that this is some type of voltage supervisor with a threshold voltage of cca. 1.22V. The package is DFN-8 and input voltage is greater than 24V. When voltage is below 23.5V the IC has its output open-drain active and disables (pulls to ground) a DC/DC buck converter.
The correct orientation could not be found as the IC went up in flames :) But I suspect the pins to be: 1 - Vin (24V+), 2 - GND, 3 - GND, 4 - NC, 5 - GND, 6 - Vin(24V+), 7 - OUTPUT, 8 - REFERENCE (24V to voltage divider to 1.22V threshold). I suspect that pins 2,3, 6 could be some settings pins.
I would really appreciate some help if someone came across this small component. This component is in the MAN Yacht motors Electronic Lever control. Checked all SMD codebooks, compared Farnell and Mouser IC supervisors to no avail.
Thank you and best regards
Offline ffranzini
Re: SMT marking AQT B A/D
« Reply #1 on: March 15, 2023, 03:56:59 pm »
Take a look of this TC1301AQTAVMF
Combined voltage regulator and voltage detector
Regards
Francesco
The following users thanked this post: Neoxy
  • Country: si
« Reply #2 on: March 15, 2023, 06:31:22 pm »
Thanks for the reply. This one was the first IC I checked. Sadly the pinout is not a match and I am certain it is not the part I am looking for as the absolute maximum Vin is 6V. In my case Vin is 24V.
Offline fzabkar
« Reply #3 on: March 15, 2023, 06:54:04 pm »
Maybe a photo of the PCB would help.
  • Country: si
« Reply #4 on: March 16, 2023, 08:40:33 am »
I took some photos but I doubt they will be of any help. The board is covered in thick lacquer and it is very hard to work with. I even went so far to decapsulate the faulty component and exposing the die to see if has any markings or at least manufacturer name on the die but was not lucky :(
  • Country: si
« Reply #5 on: March 16, 2023, 10:02:52 am »
Ok guys, I think I won :)
After giving the silicon die one more try I barely distinguished the MAXIM logo. (My stereoscope is sadly not hi end). This led me to the:
https://www.stg-maximintegrated.com/en/design/packaging/topmark.html
There were multiple hits for AQT. But After going through the datasheets I conclude the part I was loking for is the MAX16010TAB-T. Does anyone wish to confirm my findings?
https://www.stg-maximintegrated.com/en/products/power/supervisors-voltage-monitors-sequencers/MAX16010.html
Thank you for all the help. Best regards
The following users thanked this post: fzabkar
Offline fzabkar
« Reply #6 on: March 16, 2023, 03:49:50 pm »
Looks good to me. Congratulations.
Offline Swake
« Reply #7 on: March 19, 2023, 11:35:42 am »
I'm impressed!
When it fits stop using the hammer
