This is a follow-up of a SMU200A repair attempt topic I posted on 26 February 2022
I purchased a defect SMU200A on eBay, in late 2021, and when the unit arrived it had several issues.
The fans were not working, which was caused by a blown fuse on the 5.2V supply rail of the motherboard. After replacing the fuse, the unit refused to power up anymore, and after some troubleshooting this was traced back to a faulty Vega 450 PSU. Swapping the primary side of this PSU, with another one resolved the issue, and the unit booted, and remained powered up.
However, after loading the firmware an error message appeared indicating a missing "SSYN module” even though this module was physically installed. This error was caused by a faulty Xilinx - XCR3128XL CPLD, and an Atmel AT25160AN serial EEPROM on the SSYN board which had a missing Vcc pin. I replaced the EEPROM & CPLD, but I didn’t have the binary file to program the new EEPROM.
In August last year, Qw3rtzuiop, who was so friendly to open up his SMU200A, provided me with the EEPROM dump file (thanks again for that), but unfortunately by that time I had already packed-up my electronics lab, because I was relocating from Belgium to Portugal.
Well, to make a long story a bit shorter I only now finished setting up my lab, and unpacking all the gear.
So I programmed the EEPROM, and switched on the SMU200A, and to my surprise … no boot and a black screen
Troubleshooting done so far:
1) Checked all the PSU voltages, and they are within specs
2) Checked all the fuses on the motherboard, all OK
3) The HDD spins, but does not seem to do anything else
4) Bios error beeps varied; most of the time no beeps at all after switching the unit on, but one time I had 4 beeps, another time 2 beeps after applying power
5) After applying power, the unit automatically switches from standby to on, and pressing the on/STB button on the front panel does not have any effect (unit remains ON)
6) The CPU board is an FMR6+/5PCB, and the inverter board is a DAC-05B004
7) I replaced the CMOS battery with a new one
I don’t think the CFFL tubes or inverter board is bad, it seems to me that the CPU board does not boot.
9) Does anybody have any suggestions for further troubleshooting, and/or documentation from the FMR6+/5PCB, & DAC-05B004?
Thanks
