The problem with things I fix, especially when helped with tips and tricks that makes them better, is that I don't want to use them anymore, I just like looking at 'em
Ok, I'll use the work lights again but just not in crawlspaces anymore, maybe in an attic:
Not long ago I bought a tray of 50 LEDs and I wasn't sure if I'd ever use them but the tray was under $5, how can you go wrong? Bridgelux BXRC-27G1000-B-73-SE. They're about 1-3/8" in diameter and run on a off-voltage (35v?) and wires just push into built-in sockets. But now I'm thinking they could possibly be mounted in work lights like these when their LED boards go bad
Xena E, the silver solder is made by Kester, 24-7150-0018. I bought several rolls of these at the time because they were being dumped due to their old date codes. All I can say about this solder is that it just gets better with age
Thanks for the help
