I have an issue with a PAL SNES where 5V is shorted to Ground. I'm a electronics newbie, so I'm struggling to figure out where.
I attempted to install a SuperCIC modchip. When I powered the system on for the first time after installing it, I got nothing - no output, no led light. At this stage I didn't do any problem solving because I had a bit of a rats nest of wires and wanted to do a cleaner install, so I just de-soldered everything and started again. This time I decided to completely remove the original CIC chip. I left it on previously, just lifting the required legs.
I tried to power the console back on again after the 2nd install, still nothing. So I started checking things out with a multimeter. The voltage regulator was still receiving around 8.5V at it's input, but it was 0V at the output. The heatsink was also getting extremely hot very quickly. Shortly after the console had been on (a couple minutes), I was no longer reading any voltage at the regulator input either, so I presume the fuse had blown.
I then discovered there was continuity between GND and 5V at the voltage regulator. Similar story between any other 5V and GND points after that. For example there is now continuity between contacts 9 & 18 where the original CIC chip used to be. (9 should be GND, 18 should be +5V).
I have since completely removed any wiring for the SuperCIC modchip. I've removed the voltage regulator (KA7805) and the bridge rectifier (RC203) from the PCB as I wanted to rule out any problems with them. I've cleaned up all the contacts where the original CIC chip was. The continuity issue between 5V and GND still remains. There are no physical signs of damage on the PCB at all as far as I can see.
TLDR: 5V is shorted to GND and I need help figuring out how to find out where. Presuming (hoping) the console isn't already fried beyond repair...
