Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Solar battery charger repair help
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Solar battery charger repair help (Read 1639 times)
sspj9
Contributor
on:
October 25, 2015, 03:58:54 pm »
I have a portable solar 5v output battery charger. I accidentally shorted out the output voltage (positive and negative together) .. Now it wont work ughh. What seems to have blown out pls? thanks!
Logged
Kopernik
Contributor
Country:
Re: Solar battery charger repair help
Reply #1 on:
October 25, 2015, 04:01:39 pm »
For a start you will need to open it..
Logged
sspj9
Contributor
Reply #2 on:
October 25, 2015, 04:07:48 pm »
I did...
Logged
steve207a
Contributor
Country:
Reply #3 on:
October 31, 2015, 06:50:29 pm »
Hi follow the 2 wire you shorted onto the board and look to see if they are attached to any components as sometimes ive found just a wire fuse wire soldered across 2 terminals which when blown is impossible to see as it just dissapears may be in your case or maybe not but worth looking at
Logged
NiHaoMike
Super Contributor
Country:
"Don't turn it on - Take it apart!"
Reply #4 on:
November 02, 2015, 07:32:51 am »
Try briefly bridging B- to the outside of the USB socket to reset the overcurrent protection.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
