Author Topic: Solder mask peeling  (Read 1071 times)
Offline NjacksteTopic starter
  • Country: ie
Solder mask peeling
« on: February 19, 2021, 02:50:47 am »
I bought a stacker arcade machine led PCB 2nd hand but some of the solder mask is peeling how can I fix this.
I dont have specialised equipment I just have a soldering iron and some tools.
I have never replaced solder mask before and I don't know how to do it.
If I use an mg chemicals conformal coating pen will that work to insulate the PCB and to prevent shorts with the other side of the board.
Offline ataradov
    • Personal site
Re: Solder mask peeling
« Reply #1 on: February 19, 2021, 03:16:39 am »
Why do you need to replace it? It is really only necessary during automated soldering.
Given that it is peeling, I assume it is the type of the process that tins the traces first, so there should not be exposed copper that may corrode.
Alex
  • Country: ie
« Reply #2 on: February 19, 2021, 03:20:45 am »
There is exposed copper on the board it's not on traces its on through hole
Do I need to replace it.
Will it cause shorts if I dont
Offline ataradov
    • Personal site
« Reply #3 on: February 19, 2021, 03:22:53 am »
Missing solder mask will not cause shorts unless something else touches the board. But that would be a bad design no matter what.
Alex
  • Country: ie
« Reply #4 on: February 19, 2021, 03:23:35 am »
Thanks
Offline tooki
« Reply #5 on: February 20, 2021, 02:36:42 pm »
I know I’ve seen solder mask pens in a catalog, I forget who makes it. But as others have said, it’s usually no problem. What I like to do, if there’s exposed copper, is to tin it with solder so the copper won’t oxidize. But this is not in any way a requirement.
