A battery powered or gas soldering iron can be used, and if held by someone wearing an ESD grounding wrist strap, will be very unlikely to cause ESD, even if not explicitly sold as ESD safe.
I hadn't thought about that!
The
Dremel Versatip comes up as an option for this. Most reviews come up very positive, but then again they're quite superficial. Has anyone here used one?
I've browsed through several threads here on gas-powered soldering irons and there are mentions of models by Weller, Hakko, Portasol and others, but the Dremel is easy to get hold of here and doesn't cost an arm and a leg.
Besides needing it for this specific ESD-sensitive repair project I can see a gas-powered soldering iron/tool is nice for heat shrink tubing.
Alternatively I'm about to order components
from Farnell, which I see also sells various gas powered soldering irons at various prices. Obviously the more expensive brands (Weller etc.) are safe buys, but for occasional hobby use I don't want to invest too much in this, but still don't want something that falls apart after 2 times of use (or is unsafe to use).
Since this is hobbyist stuff on the cheap:
You could attach a wire to the cooler metal part of the iron that is also connected to the tip. Then ground the end of the wire. How feasible this would be, depends upon the construction of the iron.
Hmmmm... I thought about this, and checking I couldn't find any continuty between the cooler metal part (shaft) and the soldering tip itself. It appears they're isolated from each other, but after having read your post I decided to check again and indeed there's some continuity there.
The continuity/resistance reading on the multimeter fluctuates (probably due to bad contact because of the darkened "heated metal" after years of use), so I tried cleaning the shaft with household steel wool which helped a bit, but although unstable it reads around 1 MOhm between the tip and the metal shaft.
On a sidenote I measured around 750 Ohms across the two AC (230V) pins. Is this normal? It solders just fine.
