So, to clarify... I want to use this Fluxo Kester 186 Rma Lead Free 100 Ml as my everyday flux? And the Cobix for if I have corroded parts.
Yes.. I have posted 2 different very distinct situations but actually nowadays we have 3 or more ..
A) you have ELECTRIC (not electronic) joints mostly w/corrosion and HIGH THERMAL MASS
B) you have ELECTRONIC (THT or SMD) joints (may be or may be not ESD)
C) you have ESD sensitive devices
D) you have not only ESD but also a very peculiar THERMAL PROFILE (LEADED or LEAD-FREE)
In each case you have options to consider:
A) a regular CHEAP (mains plug) SOLDER IRON at least 60W or may be required 150W
with a good RA FLUX *AND* that crappy solder paste will help a lot
B) for NON ESD devices a CHEAP 30/40W SOLDER IRON is ENOUGH
there is no fun to take that 2KG BRICK transformer to solder a 12AWG wire in the CAR/BIKE/HOUSE
but you may choose - THT and SMD devices require "RMA" flux
I hate LEAD FREE STUFF - is pasty, it cracks it sucks.
I use LEADED for THT SMD with RMA flux (i don't care much about) the KESTER 186 is affordable
The AMTECH is more expensive
C) for ESD **YOU MUST** use an ISOLATED IRON and a AIR GUN will help to PRE-HEAT the PCB
for ESD **YOU MUST NOT** use that CRAPPY paste...
the temperature MUST BE OK as well
ESD SMD also requires a proper TEMP PROFILE in which the TACKY FLUX will help
I HAVE AMTECH NC-559 (expensive) for that
This particular formula works very nicely for hand soldering SMD it gives you enough time
D) ESD BGA and REFLOW.
I USE ReworkStation and PRE-HEAT with AMTECH NC-559 TACKY FLUX ONLY
ULTRA SONIC cleaner ONLY as well
FOR CHASSI AND anything WIRE GAUGE >18AWG (read bigger) i have a 150W power device
That CRAPPY PASTE is magic in that cases...
There are other options... and choices
Paul
