Electronics => Repair => Topic started by: hpibmx on July 30, 2020, 07:44:49 am
Guys recently my soldering station stopped working altering removing it and plugging it in a deferent station.
Any idea how I can check this?
I don’t have any other machine to test it, it turns on my station but the temperature won’t rise at all it’s just 000, and when I unplug it my station detect it. But putting back in recognize but no rise in temperature.
Appreciate it if you have any ideas about this too.
It’s Gordak 952 Soldering Station
Your pictures show an incomplete iron! Maybe if you re-assembled it with a soldering tip installed it might work better.
I recently had the same kind of issue, does it physically get hot?
Maby heating element is burned out. Usually it´s two resistors you can measure on the 5-pin (?) connector.
One is thermocouple and one is heating element. Heating element is around 10 Ohms or so in that range.
Nope unfortunately it’s the same
Nope not at all
I’ll have to check it by Monday we are having off now
Thank you, I’ll check and update you again.
Maby a look at schematic can help repair ?
Could be a burned out TRIAC.
Did you open the handle and aviation connector and look for breaks? That's what broke on mine. The wires are very thin for 60 watts IMO.
- Check the 26Vac supply is present on CN9
- Check if pulses go into Optoisolator Pin 1
- Maby Optoisolator bad ?
I’m gonna check on that
I haven’t opened it yet, I’m check the circuit in it thanks
