Hi All,
I am a hobbyist using a Quecoo T12-953. It was working well for years, until the fuse (250V 3A) was blown when I was working with an old TV pcb.
Perhaps I was not so careful enough. After resoldering a few spots, when the tip touched another spot to resolder, the fuse was blown. All but the fuse insider the soldering station looked okay, so I replaced the fuse, but when I turn the station again, the fuse was blown again. I removed the soldering handle cable from the station and tried again, but again the fuse was instantly blown.
What would have gone bad in the soldering station? When I measured the resistance between AC input, no shortage was shown. How could I fix it?
Comments will be appreciated very much!
