Hello,
Recently I was trying to salvage some components from a vintage PCB. Everything was great until i tried to heat up a joint to remove some solder. The solder melted and I was able to remove most of it, but the component, a DIP package, wouldn't go anywhere. How should I go about getting these components? Should I cut and file the PCB? Should I be tackling this another way?
Thank you,
VintageTech
