Author Topic: Soldering Wires to a CR2032  (Read 3059 times)
Offline tooki
Re: Soldering Wires to a CR2032
« Reply #25 on: June 09, 2021, 05:43:22 pm »
I am surprised that nobody has mentioned the (to me) obvious solution, which has worked for me.  You buy a 2032 holder.  Put the cell in it and you have solderable pins.  Replacement is easy.  They only cost a few cents on ebay.  Search 2032 holder.
Ummmm… somebody did, several messages before yours:
... I'm thinking I can solder wires to an existing 2032.
To avoid possible damage from overheating, it would be better to solder the wires to a button cell holder, and then insert your existing CR2032.
Offline coppercone2
« Reply #26 on: June 11, 2021, 01:54:45 pm »
i soldered one a while back, but I left it in the freezer first for a while, sanded the area to be soldered and cleaned it with alcohol and fluxed it. the housing that its in could take a bomb, and its been OK for like 3 months (2430)
you need to solder it in as little time as possible with as small a joint as possible to keep it from over heating
« Last Edit: June 11, 2021, 01:56:32 pm by coppercone2 »
