Does the tv have a T-con board, if so it could be related to that board and the AS19-H chip or the AS15, I've one Samsung here with bad image related to that chip that is very hot, this chip as to do with the gama, check the gama voltages they should be up or down depend on the way you mesure it, but like 2.4, 2.5, 2.6, etc, if you find it to be like 2.4, 2.2, 2.5, 2.6 it's that chip or if it's hot to put your finger in.
