Follow the setting up of the bias procedure in page 6/7.
To check, short the input and measure the voltage at speaker output at L1 to +vcc, and compare it to voltage of speaker output at L1 to -vcc.
Edit: Also check the power supply +15vdc, -15vdc, +75vdc, -75vdc.
