Author Topic: Chromebook power port fix  (Read 1777 times)
Offline drogersmvsdTopic starter
« on: April 29, 2016, 05:20:25 pm »
Hi all,
I posted this on other forums with no response hoping maybe i will get some info here.
I created a tutorial to replace the damaged parts for hp's use, after receiving the tutorial they informed me of a mistake i made when selecting replacement part i used a 1.8 amp usb they told me it should be 3 amp.
I tested the amperage and sure enough it does do a 3 amp draw..
So, I have been on a parts quest for a year now hoping the manufacture will give me a part number for a charging micro-usb port but they have not.
It is a hp g1 chromebook power usb port.
3 Amp micro, Right Angle, Horizontal, board cutout smd.
apparently only pins 1 and 5 are needed to be 3 amp as they are the power / ground pins.
Also I have contacted newark, mouser, and digi-keys staff but I was informed that there are no 3 amp micro usb parts. Which is not true at all.
here is some pics, on top of the usb it says t372
Thanks all,
Don
Offline rickb863@gmail.com
Re: Chromebook power port fix
« Reply #1 on: January 28, 2017, 03:47:12 am »
Hi Don.  Did you ever find the correct port for this? I am having the same issue and cannot find the correct port.  Thanks for any information you might have.
Offline elecman14
« Reply #2 on: January 30, 2017, 08:50:27 pm »
Not 100% sure this would be a mechanical fit but here is a 3A micro usb:
https://www.digikey.com/product-detail/en/wurth-electronics-inc/629105150521/732-5960-1-ND/5047555
