Good you caught it, the thermal fuse is usually a mile away from the bonfire...
There are a few recalls for dishwashers causing fires. Check with Whirlpool and CPSC. Other brands are just as dangerous- GE, Kenmore, Maytag, Kitchen Aid, Bosch etc.
I've seen bad pcb design: power relay pins breaking soldering joints and not enough copper making a hot spot, a connector that melted, creepage/clearance spacings violations etc. that cause insulation to break down and carbon track.
