Meh... don't think the resistors are zero.
If those resistors would have been zero, these would likely not have blown up as a '0' Ohm short doesn't (shouldn't) heat up. And there is a visible clue too:
The ending zero on the top and the bottom resistors are slightly more square than the first number on the middle resistor and than the second number on the bottom resistor.
Ok, now, what numbers are these....
Not 0
Likely not 1; 4; 5; 6; 7
Maybe 9
Probably 2; 3; 8;
Possible E12 series resistors with these number:R220; R330; R820
Somehow I have a preference for R330... eventually R220, not R820 as it somewhat unusual. Well, I might be completely wrong with this guess.
3 times R330 in parallel is close to a tenth of an Ohm. In series it is close to an Ohm.
