Author Topic: Sony Bravia KDL-52VE5 Repair Help/Red LED Flashes 6x  (Read 216 times)
Offline dklemmerTopic starter
« on: December 23, 2024, 01:23:25 am »
Hi Folks,
Newbie here with limited experience trying my hand to figure this tv out.
Similar to edy's post from late 2017, I recently acquired a Sony Bravia KDL-52VE5 LCD TV, circa 2010. 5-10 seconds after startup, the red begins flashing 6x. I have 25v going through J6711 to the three VCC pins, through a 9 pin cable to the LH inverter board. The Protect pin has 5.9v before the red LED begins flashing, then there is 0V.
If I disconnect the cable to the inverter board, all the backlights come on. I don't know if there is sound or any picture, I only see light coming through the case.
Would anyone have suggestions or even a service manual with readable schematics?
Thanks!  :-+
D.
Offline Paceguy
Re: Sony Bravia KDL-52VE5 Repair Help/Red LED Flashes 6x
« Reply #1 on: December 23, 2024, 06:29:32 pm »
I re-flowed the circuit boards on mine and everything has worked fine since then.
« Reply #2 on: December 23, 2024, 08:35:30 pm »
Thanks Paceguy,
Which circuits boards are you referring to?
