Sorry if this is a duplicate post. When I tried to post, but it would just take me back to making a post and I couldn't see anything under my account were the previous post was actually made.
I was given this TV as being bad and I'm trying to figure out if this will be an economical repair. I have a feeling the issue is with either the processor board or the T-Con board, but not sure which one would cause this issue.
If anyone has seen this before and can tell me which board should be replaced, that would help so I don't just have to buy both, or heaven forbid if the issue is actually neither. You can see vertical sections along with the horizontal ghosting around the selection buttons. There are some artifacts around the "m" in Welcome.
