If the horizontal output transistor has been switched off, then the 120V supply would be sitting at the same level as the B+ supply. Therefore, it appears that after the initial zap, some kind of protection has kicked in.
Does NL801 still light up after disconnecting the electron gun?
Is there a resistive path to ground via ABL (pin #8 of CN801)?
ABL = automatic brightness or beam current limiter
If you open one of the heater pins (H1 or H2), does the zap go away, and does the FBT develop the correct secondary voltages?
Could the internal HV capacitor be shorted to pin #11 of the FBT?
