Hi everyone,
I made a simplified schematic (with MS Paint
If i understand correctly, the 0,6v I'm getting without the sensor connected is correct because of the resistors R8633 & R8634...
So the controller should read something between 0v - 0,6v...
Tried yesterday for hours with a 220k potentiometer but still didn't find the sweet spot...
Only 1 time the tape loaded with about 0,1v to the pin 119 of the controller, but then the camera throw a different error... c:31:30 and c:32:30
S/M says: "FG fault when starting capstan"
Correction: "Load the tape again, and perform operations from the beginning." and "Remove the battery or power cable, connect, and perform
No idea what this means. of course i already tried to load the tape again and remove power 100 times
