Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Sony MHC-W55 fm presets lost after unplug from wall socket
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Sony MHC-W55 fm presets lost after unplug from wall socket (Read 617 times)
deepaksetohul
Newbie
Country:
on:
March 17, 2023, 04:28:42 pm »
HELLO .. my Sony MHC-W55 fm presets are lost when the unit is unplug from power.. Thanks send help
Logged
theHWcave
Regular Contributor
Country:
Re: Sony MHC-W55 fm presets lost after unplug from wall socket
Reply #1 on:
March 17, 2023, 06:30:13 pm »
I suppose the main unit (not the remote) has a battery. After all, it appears from a quick glance at the manual the clock keeps running even if the power is lost. That battery is probably also used to store other settings. Sadly it is nowhere mentioned and it has probably finally died. You would need to open the thing up and look for it. If you are lucky its one of those CR2032 coin cells in a holder like PCs use for storing BIOS settings. It may be soldered in. I have seen that in a couple of motherboards and other electronic gear
Logged
SeanB
Super Contributor
Country:
Reply #2 on:
March 17, 2023, 07:14:34 pm »
Sony also used supercapacitors there, normally 0.22F 5.5V rated, you would find 2, one for the RTC and the other doing the presets. they do fail, or there is a CR2016 soldered to the board.
Logged
deepaksetohul
Newbie
Country:
Reply #3 on:
March 18, 2023, 06:01:30 pm »
Thanks ... it indeed used a supercapacitor and in the MHC-W55 is the C501 thats needs to be changed
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
