Author Topic: SONY • "PROTECT" ERROR •  (Read 4251 times)
Offline PickTopic starter
« on: September 07, 2018, 04:22:35 am »
SONY
MINI HI-FI COMPONENT SYSTEM
MHC-EC909iP
Unit normally displays "PROTECT", if speaker wires "cross" or touch one another.  After resolving this "wire issue", I simply unplug the unit & then plug it back in..  It then Powers on like normal!
However, this time is different.
I've unplugged all speaker wires from the back of the unit (and still "PROTECT" error is displaying, when I power on the unit).   <---  indicating that this error is not due to speaker wires, like normal.
I notice the unit "Clicks", a certain number of times, while powering on (before finally deciding to display "PROTECT").  Does anyone know where I can learn more about this?  Perhaps the number of times the unit "clicks", before Powering On, might indicate the problem / help to troubleshoot the error?  <--  If so, where might I find such information?
Any help is greatly appreciated.
Thanks!  :)
-Pick
Josh Pickeral
joshpickeral@verizon.net
Offline SL4P
  • There's more value if you figure it out yourself!
Re: SONY • "PROTECT" ERROR •
« Reply #1 on: September 07, 2018, 07:46:46 am »
I’d guess the earlier short circuit has taken half or both the output transistors on one or both channels.
The protection logic is sensing DC where it shouldn’t be - and let’s you know, so you don’t fry the speaker coils.
Good luck.
Don't ask a question if you aren't willing to listen to the answer.
Online tooki
« Reply #2 on: September 07, 2018, 09:51:42 am »
Service manual came right up on Google: https://elektrotanya.com/sony_hcd-ec709ip_ec909ip_ver-1.0_sm.pdf/download.html
If you let Google suggest "Sony MHC-EC919iP Protect mode", you find lots and lots of discussions of the problem. 3 minutes of skimming suggest a few different fixes:
1. unplug, wait a bit, plug back in,
2. #1, but also spin the fan (by hand or with canned air), or
3. replace failed power amp IC
« Last Edit: September 07, 2018, 09:57:52 am by tooki »
Offline radioFlash
« Reply #3 on: September 08, 2018, 02:20:53 am »
In addition to what has been suggested:
Check for physical damage--anything obvious like bulging caps or scorch marks?
Try tapping around with a plastic prod of some sort to see if behavior changes in case there's a bad solder joint or connection
Check the power supply voltages, particularly the standby voltage.
I had one Sony receiver that had random relay clicking and resetting due to bad solder joints (the Power supply was soldered to the PCB)
I had another Sony receiver clicking on startup and sometimes come up with Protect because the caps for the standby power supply were bad
